Hey Guys, So I am having trouble with the UV map for some reason when I mark seam and unwrap it doesn't show on the UV sc…
Forum Archive Hey Guys, So I am having trouble with the UV map for some reason when I mark seam and unwrap it doesn't show on the UV sc…
  • #4488
    osokxshadowx1
      Hey Guys,
      So I am having trouble with the UV map for some reason when I mark seam and unwrap it doesn’t show on the UV screen unless I have the entire monkey selected, also cannot add seams to the ears because then the entire UV map disappears any help would be appreciated.
      #22627
        Hi @osokxshadowx1, the ability to view UV’s of your mesh is dependent on which parts of your mesh are selected – by default. You can enable the “Keep UV and edit mode mesh selection in sync” button to view your UVs independently of mesh selection. It’s located to the right of the pivot selection in the UV/Image Editor.
      • The topic ‘Hey Guys, So I am having trouble with the UV map for some reason when I mark seam and unwrap it doesn't show on the UV sc…’ is closed to new replies.
