Help: Particles
Forum Archive Help: Particles
  • #18346
    Kerri 3D
      Hi everyone! For the life of me, I cannot figure out how to change the size of my particle spheres.
      In the pic I uploaded, the top one is mine and the bottom one is the tutorial I’m following. His spheres are much smaller, and more spread apart, which I’ve attempted to replicate numerous times.
      I’ve tried:
      -Resizing my emitter (which is a round cube),
      -Under Particles>Render, I’ve tried changing the Scale,
      -Under Particles>Textures, I’ve tried adding a new texture, changing the Type to Blend, then under Influence, disabled General Time and checked Size, and under Colors, I’ve even added a Color Ramp where adjusting the white was supposed to manipulate the size.
      To absolutely no avail.
      It seems like the instructor has had more control over his render result with the spheres smaller and spaced further apart.
      So, my question is – does the sphere size/spacing ultimately have any impact on the end result?
      And if it does, is there any other trick I can try? I’m still working in 4.0.2, but also tried the steps above in 4.2.0 and they didn’t work in that version either.
      Thank you in advance 🙂
      #87605
        Hi Kerri @Kerri.3D ,
        Make sure you Render as Object, not as Halo (the default):
        #87606
        Kerri 3D
          Hi Martin @spikeyxxx
          I actually wanted to know if I could resize the spheres pre-render, but when I finished the project it turns out it didn’t matter much, lol. I was able to get the [final] particles the way I wanted them, which are in the new pic below.
          But thank you SO much for the screenshot and for responding so quickly (as you always do 🙂). You’re awesome.
          Cheers-
          Kerri
          #87607
            HI Kerri,
            That was what I understood. Although it says Render in the Particles Properties Panel, that is also how they are shown in the Viewport (pre-Render), at least when the Viewport Display is set as Rendered (which it is by default).
            But anyway, glad you got it working!
          • The topic ‘Help: Particles’ is closed to new replies.
