hello =) I don’t know why the Bevel modifier (9:20) doesn’t work when I apply it
Forum Archive hello =) I don’t know why the Bevel modifier (9:20) doesn’t work when I apply it
  • #20260
    rachid yous
      hello there, I hope my report find you well =) I don’t think I did something wrong since I follow every single steps of the tutorial but I guess we all always think that way.
       I don’t know why the Bevel modifier (9:20) doesn’t seems to affect my consol work applied it, perhaps it is related to the version last of blender ?
      Off course I tried what you Teached us in previous lesson, so I recaculated the inside and outside just to be sure but it didn’t seems to change the initial issue I encounter.
      looking forward =)
      Rachid From FRANCE
      #95258
        Hi Rachid @gecko ,
        Could be a few things. The first thing to do, is to get rid of possible ‘double Vertices’; Select everything (in Edit Mode) with A and then M > Merge > By Distance.
        You should probably also disable the Clamp Overlap, like so:
        And to avoid further problems, make sure the Scale is Applied; in Object Mode: CTRL+A > Apply > Scale.
        Let us know if that helps.
        #95259
        rachid yous
          HI Martin thank you so much for your reply,
          I did mesh everything by distance and now it seems to work better.
          I also like in the video didn’t use the Clamp Overlap. thank you so much for this support if feel warm to have the possibility to interact with you in those clumsy situation thank again Martin really appreciate =)
        • The topic ‘hello =) I don’t know why the Bevel modifier (9:20) doesn’t work when I apply it’ is closed to new replies.
