Having problem grabbing the cut.
Forum Archive Having problem grabbing the cut.
  • #20706
    Gabriel Cruz
      When I try to grab the cut, it is also bringing the right part of the vertices and the left part are acting strangely, It is also leaving those small vertices at the top.
      #96915
      Gabriel Cruz
        #96916
          Yes,
          Extrude first, then pull it down.
          (You’re not the first one to make that mistake😉)
          #96917
            You can see him extrude it and you can see it in the screencast keys as well in that part of the video.
            #96918
            Gabriel Cruz
              Bruh, I legit just realized this seconds before reading the comment, guess I just had a severe case of dumb. Thank you guys anyway.
              #96919
              Casey Knapp
                No I did the same thing i was so confused. thanks for posting.
              • The topic ‘Having problem grabbing the cut.’ is closed to new replies.
