Having issues repeating this tutorial as my render results is always wrong for some reason? I've set it up exactly like…
Forum Archive Having issues repeating this tutorial as my render results is always wrong for some reason? I've set it up exactly like…
  • #5053
    Daniel Widegren
      I’ve set it up exactly like the video did with the render layers, it renders each layer correctly when I see the screen, first the orb, then the rest of the objects and then the backdrop, it’s as well correct when I just render in the scene as well all seems to be setup correctly.
      Hwoever so fast the render is done and I want to preview the layers… I can’t. The first 2 layers is the first layer no changes, the third layer is now the second layer… The names are wrong, except the Orb is well the orb, Other is as well the orb and the backdrop is now ‘other’ for some wierd reason.
      I’m not sure if I’m doing something wrong or if I encountered a new bug in blender 2.75?
      #23388
        That sounds pretty weird..maybe it is a 2.75 bug. I recommend trying to follow the lessons again from scratch. If you get the same problem then report it as a bug.
        #23389
        max k
          It was indeed a bug, fixed in blender v2.75a, on 08 July 2015.
          #23390
            Oh nice! Thanks for following that up and getting it solved.
          • The topic ‘Having issues repeating this tutorial as my render results is always wrong for some reason? I've set it up exactly like…’ is closed to new replies.
