Hand does not Rotate with Elbow_pole.L
Forum Archive Hand does not Rotate with Elbow_pole.L
  • #20311
    John Frey
      At approximately 18.08 Minutes into the tutorial:
      When you move the Elbow_pole.L up and down with G your arms DEF-Arm_Upper.L, DEF-Forearm.L and DEF-Hand.L all rotate.
      When I move the Elbow_pole.L up and down with G only DEF-Arm_Upper.L and DEF-Forearm.L rotate, DEF-Hand.L doesn’t rotate.
      I can’t figure out what I’m doing wrong.
      Any suggestions where I went wrong?
      #95459
      Wayne Dixon
        Hey John,
        In the end you don’t want the hand to rotate when the elbow moves. So it’s possible that you have inadvertently already done something that I later do??
        It’s impossible to tell without looking at your file, but I wouldn’t worry about that.  Just keep going, if it’s still a problem* when the arm is complete then check it against the finished rig.
        *it’s not a problem at the moment
      • The topic ‘Hand does not Rotate with Elbow_pole.L’ is closed to new replies.
