It is using the Material and texture from the ground and not it’s own. When I go into the particle system settings, it won’t let me change the material (it is greyed out).
Hey Albert, if you’re using Object for the emission, then you can change the material by changing what’s assigned to the source object itself instead of changing it from the particle settings.
