grass has grey patches
Forum Archive grass has grey patches
Viewing 10 posts - 1 through 10 (of 10 total)
  • #16595
    GRL KRASH
      For some reason my grass doesn’t look like the one in the tutorial. It has grey patches. Any idea what’s wrong?
      #80141
      GRL KRASH
        #80142
        GRL KRASH
          also could be helpful to note that when I change my second Hair BDSF to reflect color, it colors the grey patches
          #80143
            Hi @grlkrash ,
            your .blend file would probably be helpful in this case…
            #80144
            Adrian Bellworthy
              Well to start with, the Noise Texture, Bright/Contrast and Overlay nodes are doing nothing.
              The Random output on the Hair Info node plugged into the color ramp is picking a random value from the color gradient you set on the color ramp.
              The colors you use on the color ramp, unless exact as in the course, will produce a different result.
              #80145
              Jonathan Lampel
                Does the color of the grey patch change when you change the environment texture? It could be that it’s too reflective in those areas and just reflecting the grey environment. Possibly because the normals are flipped on the objects those patches are made of? Like Martin mentioned, it’s hard to know without poking around the file.
                #80146
                sheila5
                  it might not be what you want but it’s very realistic. the grass here is patchy as hell because of the drought
                  #80147
                    The mystery of the grey patches. Can’t wait to see how this turns out.
                    #80148
                    GRL KRASH
                      how do I attach my .blend file here?
                      #80149
                        You can upload it to Dropbox or Google Drive and post the link here so we can download it. Be sure to add all the external data that we would need to open the file correctly.
                      • The topic ‘grass has grey patches’ is closed to new replies.
