‘g’ to rotate roots near part doesn’t seem to do the trick.
Forum Archive ‘g’ to rotate roots near part doesn’t seem to do the trick.
  • #8318
    theavatrol
      The hair around the part-area sure is tricky.
      I’m using Blender 2.79 and when I press ‘g’ with the root selected, the entire hair just moves off of the scalp mesh.  I made sure root is deselected.  If I try the same with root on, the entire root just goes into a mad spiral, even if I hold shift down.  I tried rotating as well, and it doesn’t seem to do much.  Any advice/idea on what I might be doing wrong?
      Cheers.
      #28512
        Can you possibly record a screen cast of what’s happening exactly? It’s hard to understand via text only..
      • The topic ‘‘g’ to rotate roots near part doesn’t seem to do the trick.’ is closed to new replies.
