For those who expect some problems with de defocus node it don't work on windows 32(on 2.76b). it's working fine only with…
Forum Archive For those who expect some problems with de defocus node it don't work on windows 32(on 2.76b). it's working fine only with…
  • #5073
    ratonsky
      For those who expect some problems with de defocus node it don’t work on windows 32(on 2.76b). it’s working fine only with windows 64.
      #23416
        Yikes, thanks for sharing the tip. I wonder if that’s a bug in need of reporting.
        #23417
        Vanilson Azevedo
          I tried to use defocus on blender 2.77a and it’s not working. Enabled Use Z-buffer and plugged the Depth socket of the image into Z socket, changed the F-Stop and doesn’t work.
          #23418
            You’re sure the same setup works in previous versions of Blender? If that’s the case you it might be wise to submit a bug report.
          • The topic ‘For those who expect some problems with de defocus node it don't work on windows 32(on 2.76b). it's working fine only with…’ is closed to new replies.
