For the rotate/slide contours widget, left clicking a loop to bring it up like you say doesn't work. However, right click …
Forum Archive For the rotate/slide contours widget, left clicking a loop to bring it up like you say doesn't work. However, right click …
  • #6187
    cm87
      For the rotate/slide contours widget, left clicking a loop to bring it up like you say doesn’t work. However, right click does this. Also, I found whether I want to rotate or slide depends which initial direction I move my mouse.
      #25017
      cm87
        Oh you mean like if you set you system mouse settings to be left-handed?
      • The topic ‘For the rotate/slide contours widget, left clicking a loop to bring it up like you say doesn't work. However, right click …’ is closed to new replies.
