For anyone who has problems with snapping, and also scaling bottom part, check your transform pivot point.
Forum Archive For anyone who has problems with snapping, and also scaling bottom part, check your transform pivot point.
  • #12616
    Bohdan Skochii
      Title. Don’t ask how many times I redid everything… Checked all questions before, and none helped.
      Gladly I found an issue. Set your Transform Pivot to median. Hope it’ll help someone 😀
      #59899
        Thanks for sharing this tip! My apologies if I didn’t make it clear in the video.
        #59900
        Bohdan Skochii
          It’s all good, this is the way. Now when I figured the problem myself, I really learnt something.
          #59901
          clydefrog
            Thank You!
            #59902
            turtlelearns3d
              Im glad you commented on that! I don’t know why that result didn’t happen for me, but I started playing with it cause of your comment.  I was originally on closest and it was only snapping to the outside vertex. Then switched to median and no snapping occurred. Then I went back to closest and it worked. Thank you!
            • The topic ‘For anyone who has problems with snapping, and also scaling bottom part, check your transform pivot point.’ is closed to new replies.
