Font Solidify Problem
Forum Archive Font Solidify Problem
  • #16071
    Hi,
    After I applied solidify to the letter, some part of it are not being solidified properly. May I know why? It’s getting worst if I click even thickness.
    Before solidify:
    After Solidify:Solid2.png
    Even Thickness is applied:Solid3.png
    #78066
      Hi @Zulfariz ,
      That looks suspiciously like inconsistent Normals: SHIFT+N to recalculate them (with all the Vertices selected).
      (For good measures, you can do M > Merge by Distance before that.)
      #78067
        When I covert text to a mesh, normally it comes out with really messed up topology, double vertices, flipped normals etc, etc. So I typically just go into the mesh and fix all of the topology issues as if I was modeling it from scratch, because if I don’t and I want to use a modifier such as solidify, it’ll just get all wonky and it’s a pain to work like that. So yeah, I suggest you take the time, go in and get rid of extra loops and all that other good stuff and get the modeling to tip top shape.
      • The topic ‘Font Solidify Problem’ is closed to new replies.
