Fill tool problem [SOLUTION?] I noticed in one of my unrelated projects that the fill tool seemed to be working perfect…
Forum Archive Fill tool problem [SOLUTION?] I noticed in one of my unrelated projects that the fill tool seemed to be working perfect…
  • #5033
    Jed Staton
      I noticed in one of my unrelated projects that the fill tool seemed to be working perfectly well for me – i.e. a single click would give me a perfect representation of the colour I had selected, unlike what you (and indeed I) had experienced with this project.
      This gave me a chance to compare a working instance of a Blender project alongside a ‘faulty’ project to try to get to the bottom of the issue.
      I think I have a solution:
      If you are using the fill tool in texture paint mode and experience the I-have-to-click-a-billion-times-to-get-the-right-colour issue, in the 3D View toolbar menu, go to ‘BRUSH’ and make sure that ‘Unified Strength’ is UNticked (I suspect that it will be ticked if you’re experiencing the problem).
      Note that unticking this seems to reset your brush strength to 50%, so whack it back up to 100, and try it out. From what I can see, this should solve the fill issue …
      Hope that helps.
      #23362
      Jed Staton
        Also, it seems that you CAN re-enable Unified Strength after you’ve whacked up the fill strength to 100% (whilst Unified Strength is disabled).
        It looks like the bug – and it clearly is a bug – is that when Unified Strength is enabled, the fill strength is locked at whatever value it was at when Unified Strength was ticked (regardless of what you adjust the strength value to).
        So, in effect, what we were seeing is the fill tool locked to 50% strength under the hood, but it was *saying* 100%.
      • The topic ‘Fill tool problem [SOLUTION?] I noticed in one of my unrelated projects that the fill tool seemed to be working perfect…’ is closed to new replies.
