File starts up with basketball, when i change it to blue paintball, it switches back to baskett ball when frame changes. How can i keep it on paintball?
Forum Archive File starts up with basketball, when i change it to blue paintball, it switches back to baskett ball when frame changes. How can i keep it on paintball?
  • #7238
    tonycam123
      Wayne Dixon
        It sounds like you have a keyfame set on that property and when you are changing frames it is updating to the keyed value.
        if you don’t want it to change, ‘clear keyframes’ on that ‘ball_type’ property (right click > clear keyframes)
        #26734
        Markus Berg
          I had the same problem and I just realized what the issue is. When you open the exercise file, there is a message at the top of Blender saying “Auto-run disabled”. And if you press “Reload trusted” the ball will become the plainball automatically.
        • The topic ‘File starts up with basketball, when i change it to blue paintball, it switches back to baskett ball when frame changes. How can i keep it on paintball?’ is closed to new replies.
