fake “sun glow” not visible in the render
Forum Archive fake “sun glow” not visible in the render
  • #18323
    Hi, I do not see the “fake sun glow” in my renders (even in the viewport render) although it is visible in the viewport. The Sun_Glow_Disk object with the gradient shader is enabled in the outliner. I am using blender 4.1
    What can I do to fix it?
    #87499
      Hello. Can you give us a screenshot or two of your render or UI to see what’s wrong. Maybe walk was through what you’re doing and your settings. So overall a little more context.
      First thing I can think of is that maybe the render icon in your object is disabled in the Outliner. You may have it enabled un-hidden, but renderability may be off. Also maybe you forgot to change the alpha blend in the settings.
      #87500
      Hi Omar,
      Below are some screenshots. The render icon is enabled and the blend mode is set to alpha blend.
      This is a screen grab of my viewport:
      This is a render result ( without the fake sun glow 🤷🏽 somehow):
      And the is a snapshot of my UI:
      #87501
      Dwayne Savage
        Do you have Bloom checked under render tab of the properties editor? Note: If you’re using 4.2 you will need to use Glare node set to Bloom in the compositor editor.
        #87502
          Hi Bartlomiej @the_grzyb ,
          I can’t see what’s causing that, from your screenshots alone.
          Have a look at you Compositing Workspace. Also, disable all third party Addons.
          If nothing helps, you could upload your .blend file to Dropbox, Googledrive, or so and post a link here.
          #87503
            That is weird indeed. If you can upload your blend file for us to take a look. Remember to pack any resources in the blend file.
            #87504
            Adrian Bellworthy
              My favourite part of the whole sessions series at ~23:35, daddies happy smile.
              I can see several discrepancies, your color ramp controlling the alpha is mostly white (No Alpha). The emission strength is at 20, I think Kent settles on 0.2, you have 3 cameras in the outliner, which one are you rendering?
              You’re disk is in front of the lights and you have set shadow mode to alpha hashed.
              I don’t know which or if any of these are causing the issue, but there are many potential problems.
              I think you should re-adjust the settings to closer match the video then adjust to your liking from there.
              As mentioned, if this is still a problem, share the blend file and we can better track down the issue.
              #87505
                “My favourite part of the whole sessions series at ~23:35, daddies happy smile”
                Aww it’s one of mine too admittedly 😊
              • The topic ‘fake “sun glow” not visible in the render’ is closed to new replies.
