Failing miserably here :-( I'm trying to simply colour my pumpkin for the compo, i've previously unwrapped etc, and in Ve…
Forum Archive Failing miserably here :-( I'm trying to simply colour my pumpkin for the compo, i've previously unwrapped etc, and in Ve…
  • #5034
    killer-wolf
      Failing miserably here 🙁
      I’m trying to simply colour my pumpkin for the compo, i’ve previously unwrapped etc, and in Vert Colours i’ve put a plain orange. when i do the Bake bit, nothing happens. i’ve tried an existing image and a new UV Grid image, and each time the UV window changes to a New empty grey grid and i get the “no object or image to bake to” error. i’m following what you’re doing as fara s i can tell, maybe i’m not understanding you when you say you need to assign a texture to the UVs? i tried creatign a new image and unwrapping agian, that didn’t work either.
      TIA
      #23363
      killer-wolf
        Ok, suddenly worked; i selected all in Edit Mode, created a new image and Baked. the only thing i did different (i’m 99% sure) was in the UV window i did Paint mode and scribble a bit to make sure the image was assigned.
        #23364
          Assigning the texture with all verts selected in Edit Mode is indeed the important part. Otherwise the bake system doesn’t have a target to bake the information.
        • The topic ‘Failing miserably here :-( I'm trying to simply colour my pumpkin for the compo, i've previously unwrapped etc, and in Ve…’ is closed to new replies.
