Face mounth shape
Forum Archive Face mounth shape
Viewing 12 posts - 1 through 12 (of 12 total)
  • #15927
    maxcady
      I did the fifth course. I don’t want to mess this up. What do you think?
      #77502
        The shape of the mouth looks good from front view Max. Maybe it could be a bit wider…
        What I would do (and did), is re-doing the first 4 lessons a few more times; that is the base, you are going to work with and it should be as good as possible. Save all those .blend files so you can later look at the improvements you made. But of course everybody has a different way of learning; it’s completely up to you
        As to your earlier question regarding the head shape, compare this (my head is far from perfect as well!):
        #77503
        maxcady
          I make increment save. If I am not happy I can go back. The nose is too thick and the lips seems too big. I can change it.
          #77504
            Good thing is Max, you’re doing great. You’re improving little by little and you’re dedicating time to practicing and leveling up. Little by little, one click at a time.
            #77505
            maxcady
              the facial course is kinda hard.
              #77506
              Craig Wieland
                Is there an image you are working from? I find that the face is the hardest, and I myself struggle with it. from experience with other teachers. I was always told to work on proportion first, and I think that is what you are doing. I feel the nose is too straight.539B23-1024x1024.png
                it may help to use the grease pencil. draw out the shape you want, then alter the mash.
                Anyway good job, and I hope this helps you.
                #77507
                maxcady
                  Yeah. I don’t know why it ended like that. I will try to correct it. It’s a Christopher Reeve’s nose lol.
                  #77508
                  Craig Wieland
                    Hey I just started the class, I am on stage one. I see you are working off the Loomis method.  love it!
                    #77509
                    maxcady
                      So there is a name for the calculations? Loomis? I missed that cause I’m french from Quebec.
                      I rectify a little bit the nose. I added a picture for the post. See for yourself.
                      #77510
                      Craig Wieland
                        I am in boring Nevada, so cool to talk with you. this class is going to challenge me, so I am hoping for feedback as well.
                        #77511
                        Craig Wieland
                          One thing to note is I did not know you were in the blocking stage, so I think you are doing good.
                          #77512
                          maxcady
                            It’s written on my post: The first 5 course. 🙂 I can follow you so I can comment. But I am far from an expert. I don’t even have 4000 points.
                          • The topic ‘Face mounth shape’ is closed to new replies.
