Extruding not working
Forum Archive Extruding not working
  • #20202
    Xavier Le Bitouzé
      Sorry to bother you on this other part.  I’m currently following your tutorial, but when I extrude the faces of my roads in Edit Mode  the result doesn’t look like yours. Instead of keeping the thickness and smooth corner transitions, my extrusions distort the layout. I used the same geometry and node setup as shown. Could this be related to the curve resolution, normals, or a missing modifier setting?
      #95079
      Xavier Le Bitouzé
        Mike Hodgetts
          Hard to tell exactly what the issue is without seeing the full nodetree – can you send a screenshot of your full nodes, or send me the file?
          #95081
          Xavier Le Bitouzé
            Yes I can do that  here is my .blend file
            #95082
            Mike Hodgetts
              Found it! The Separate Geometry node in your Road Curves group is set to point – needs to be set to Edge.
              #95083
              Xavier Le Bitouzé
                Thanks you! You are a real life savor 👍
                #95084
                Nathi Tappan
                  Ha! I had the same issue. Thanks Xavier for asking the question, and Mike for the detective work!
                • The topic ‘Extruding not working’ is closed to new replies.
