Extrude and smooth shading doesn’t give the inset on 2.79
Forum Archive Extrude and smooth shading doesn’t give the inset on 2.79
  • #7644
    Andrew Elliott
      Applying the extrude and then smooth shading does not give the offset as it does on your model. It does give the smooth shading but there is no extra geometry added to the mesh. I thought I could use the inset tool to give the same affect but it doesn’t seem to give a consistent even border. Any advice?
      Update… It does work but I didn;t need to extrude first, just apply the inset.
      #27423
      Andrew Elliott
        Tried to update this question but like last time on another tutorial it does not allow the deletion or update of any comments?
        I managed to get the same using the inset tool, my  mistake was not undoing the extrude first.
      • The topic ‘Extrude and smooth shading doesn’t give the inset on 2.79’ is closed to new replies.
