Extrude and Alt S
Forum Archive Extrude and Alt S
  • #16168
    Brad Wheeler
      I found the only way to extrude the faces is by hit E then ESC then Alt S and can extrude along the normals without problem
      #78372
        Yes, you can also extrude along the normals while in edit mode with Alt + E
        #78373
        Adrian Bellworthy
          Correct! When two or more faces are selected that are facing in different directions.
          However,
          When one face is selected, E will extrude in the normal direction (local Z axis).
          When two or more faces are selected E will extrude in the median direction of the Normals of all the selected faces.
          Unless, when selecting the four faces of a cube in a loop for example, i.e. Top, Bottom, Left and Right or Left, Right, Front and Back, then the extrude will happen in the Global Z axis.
          But you can also select the axis by pressing X,Y or Z.
        • The topic ‘Extrude and Alt S’ is closed to new replies.
