Examples of when high key lighting is used in cinema
Forum Archive Examples of when high key lighting is used in cinema
  • #18580
    Justin Hardy
      I really loved the concepts covered in this video, but the use case for high key lighting isn’t immediately obvious like it is for low key lighting (this video shows many dramatic examples of low key lighting which is a common look in cinema, but there’s only one short clip from Midsommar to give an example of high key lighting).
      For me, the first thing that came to mind was Wes Anderson films. There are usually virtually no shadows in his films as the entire emphasis of his filmmaking is placed on the composition and colours of his scenes. I think this is a key takeaway for how to effectively integrate high key lighting – if your lighting doesn’t serve compositional purposes, then the objects in your scene itself probably should.
      Would love for others to share effective examples of how high key lighting can be used cinematically!
      #88751
        Wes Anderson is a good example. One movie I didn’t appreciate how cool it was in terms of lighting and composition was Guardians of the Galaxy 1 and 2. I saw it again some time ago and I was like dangs, there’s shots here that look awesome.
        #88752
        Blaine Jensen
          This video does a good breakdown of lighting. They talk about high and low key around the 6min mark. This is part of 4 separate videos on lighting I believe. Studiobinder does a really good job of breaking down shots and cinematography, well worth the watch. Linking now:
          https://www.youtube.com/watch?v=r2nD_knsNrc
        • The topic ‘Examples of when high key lighting is used in cinema’ is closed to new replies.
