Everything is different on new versions of Blender
Forum Archive Everything is different on new versions of Blender
  • #16720
    Maiil Tahiiev
      The settings are organized in different parts of interface, some are even missing.
      #80652
        Yes, that’s normal. Blender changes a lot as it’s developed and tutorials get outdated extremely quick. If you want to follow exactly as you see in the video, I suggest you download the Blender version that is being used in the tutorial. The knowledge is the same, it’s just the interface that changes.
        #80653
          Yes, each version of Blender is different.
          The easiest thing to do, if you’re having troubles with version discrepancies, is to use the tutorial version (in this case 2.78), when following along.
          At some point, you will know Blender well enough, that you can follow any tutorial, no matter how old, while using the latest Blender version.
          Never give up!
          #80654
          Shawn Blanch
            You’re going to come across this with every software. Heck even excel ribbon has drastically evolved over the years and even between OS’s.
            We can all relate. But yeah I agree with the above. Use the blender version of the tutorial if it becomes frustrating enough.
            #80655
            chihwah li
              Most things you will be able to find back. Settings are organized differently. If you cannot find a particular setting. Does not matter much. Try to follow as much as you can. Save the project, then start tweaking till you like it. It is not possible to re-create exact the same. Different blender version different default values of nodes, etc.
              As for the hair info node, in another post on CGcookie, use a “curve info” node. Some nodes you can replace or re-create with a combination of nodes, or the setting is re-named. Also possible. I am using Blender 4.5.7 LTS, and could re-create the results.
              This might be a short course, but it sure packs punch for this tiny one! I actually like these kind of courses. Short and precise. Not follow a video for hours to get results. Hope you guys make more smaller ones.
            • The topic ‘Everything is different on new versions of Blender’ is closed to new replies.
