Whenever I use bevels and solidify modifier, in every tutorial people always have even bevels and extrudes, mine look like this, any tips on how to fix this issue? I’m doing the physics core course and can’t find a way to solidify this object correctly
I would second Dwayne. Select your object and in the n-panel under item or in the object properties under transform check if the scale is 1;1;1, if not ctrl+A and apply scale. That should fix it. Also note that on non-rectangular objects you gonna want to toggle “even thickness” in the modifier.
