[ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender
Forum Archive [ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender
Viewing 15 posts - 106 through 120 (of 403 total)
  • #41448
      @arev Oh no – can you not open the file at all? Or is it tricky getting your images pasted into the provided boxes?
      #41449
      yukino hatake
        @silentheart00
        @theluthier well I still can open the file and render but as soon as the render is done it turn into a blank pure white image.
        #41450
        silentheart00
          @yukinoh1989 I tested your render scene and it’s working just fine for me.  That’s completely bizarre.
          #41451
          silentheart00
            Morten Fjellheim
              @theluthier I can open the file and get one image in. Its switching to the other one that i cant figure out.
              #41453
              yukino hatake
                @silentheart00
                sadly this isnt solving it eighter . i do notice when i open it in 2.8 and render there i do get a good render (at the end i dont get the white screen) . its kinda strange this happens but guess ill continue to work in 2.8 . just sad the node wrangler doesnt work there 🙁
                #41454
                Matthew Sheffield
                  Hello – I’m not sure if this is the right place for this question.  I am trying to do the course – shading the “Sci-Fi Helmet” – I never made one so am not sure where to find the helmet.  Can anyone point me to where I could get one for the exercise?  Thank you 🙂
                  #41455
                    @matthew1917 This is the right place to ask. If you click on the cloud + down-arrow button to the right of the lesson title, it will reveal the source file download that contains the helmet model:
                    #41456
                      @arev Could you paste your second image and simply scale + crop to fit over the box that’s giving you trouble?
                      #41457
                        @yukinoh1989 Sorry to hear about your troubles with the white screen..I’ve never experienced that problem before. And it’s odd that silent can’t reproduce the error with your file..
                        Perhaps try opening a fresh new Blender file and appending all the objects from your white-render scene into the fresh scene. That may eliminate a rogue parameter that’s causing the white render.
                        #41458
                        Morten Fjellheim
                          @theluthier it’s pasting i am tryning. But i cant figurer out how to selvet it (the box).
                          #41459
                            @arev What do you mean “selvet”?
                            #41460
                            Morten Fjellheim
                              @theluthier stupid autocorrect. I mean select.
                              #41461
                                @arev You shouldn’t have to select the box. Just select your image and scale it down, crop if needed to fit over the box template. Leave them as separate layers.
                                #41462
                                Morten Fjellheim
                                  @theluthier i will try when i get home……
                                • The topic ‘[ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender’ is closed to new replies.
