[ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender
Forum Archive [ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender
Viewing 15 posts - 76 through 90 (of 403 total)
  • #41418
      @purplekaleidoscope77 As Aaron said, yes you absolutely can. Honestly I wouldn’t turn you away if you asked that question in week 3. But you’re sliding in with time to submit homework for all 4 weeks. Welcome!
      #41419
        Looking good @arev! Is one lamp a different color than the other?
        #41420
        Morten Fjellheim
          @theluthier All the lamps have had their colour adjusted by hand so they might not be acurate. Its a wip so i thought i could change them in the final version.
          #41421
          yukino hatake
            Is there any tutorial that covers how to make dust scratches to later use as image textures? And how to make a bump image I think it was called.  To make it look like it has depth or will we see that next week @theluthier
            #41422
              @yukinoh1989 This tutorial covers procedural scratches including bump. I recommend giving that a try.
              #41423
              Morten Fjellheim
                @theluthier I cannot get that template thing to work. I dont have photoshop so i use gimp. I am not that technical so i cant figure out how to get both images in (i get one in). Another issue is that the image looses its quality drastically. So because i cant submit my homework iam stuck.
                #41424
                yukino hatake
                  @theluthier. Hey thank you for the tutorial. So bump is to add like depth then? Guess I’ll have to remake the toy. Somehow I cannot enable the node wrangler  to see the effect. Also what is the dirent with black and white value and colored ones with the node wrangler?
                  #41425
                  yukino hatake
                    @theluthier  Question : i am following youre tutorial to see if i can somehow start to understand everything . but i have a problem .
                    i am at 8 minutes where you use the noise texture and use the node wrangler to see a preview .
                    How come that mine is so white compared to yours from in the tutorial ? its kinda strange that without anything diffrent that its not the same yet .
                    This is how it looks at my file .
                    Its actually hard to see the noise at all trough in the tutorial you see a clear diffrence 🙁 .
                    if someone else can help that is fine too 🙂 got to get this finished 😀
                    #41426
                    Aaron Rudderham
                      @yukinoh1989 Not sure if this will solve your issue but it appears you have plugged the Faculty port into the the viewer node whereas Kent plugged the Colour port in, maybe give that a shot.
                      #41427
                      Aaron Rudderham
                        Also out of curiosity are we going to get a report card or something similar? I imagine @csehz is rather busy so naturally it’s no worries if we don’t but I thought it was worth an ask.
                        #41428
                        yukino hatake
                          @thecabbagedetective
                          hey  thank you for trying to help figure out the problem. indeed when you first follow the tutorial he does that and get all sort of soft collors but then replug it what should result in black and white with grey . but for me its more white then someting else xD
                          I did also tryed the colour port but also that is relative much white . compared to kents tutorial i should get collors then 🙁
                          #41429
                          Aaron Rudderham
                            @yukinoh1989 Think I may have figured it out. Under the “Preview” tab there’s the “Surface” tab, open that up and look at the strength. If it’s too high it’ll glow like that.
                            Here it is at a strength of 0.5
                            And here it is with a strength of 50
                            Hope that helps!
                            #41430
                            yukino hatake
                              thanks aaron . it does change it more to what kent has. trough its strange since with him he has a value of 1 so i do wonder what the problem could cause that its diffrent .
                              gonna check if the rest will work out well 🙂
                              #41431
                              Aaron Rudderham
                                @yukinoh1989 Good luck!
                                #41432
                                yukino hatake
                                  Thank you so much as well @theluthier for the help. i finally managed to get scratches 😀
                                  Trough i didnt understand the bump map and removed it i got a somehow better effect for the metal of the wheel and the plastic .
                                  If i can ill add dust but i am not sure ill be able to do that in time . so for now ill post the result i got so far .
                                  you really are a livesaver aaron 😀 now i managed to somehow finish it in time
                                • The topic ‘[ENDED] BC4-1810 – October 2018 Class Homepage – Shading & Lighting with Blender’ is closed to new replies.
