emission map showing weird white spots please help
Forum Archive emission map showing weird white spots please help
  • #15893
    Norb Fry
      baking pore emission map, but the mesh seems to be covered in white spots in some areas. has anyone experience this before? Screenshot (8).png
      #77368
        Hi Norb,
        This was mentioned somewhere before and it might have something to do with the Scale:
        You can give that a try
        #77369
        Norb Fry
          thanks! ive dialed it out with colour ramp in nodes when setting the shader up, next time i see this i will try your method. thanks again
          #77370
          Norb Fry
            that doesn’t seem to work, whether you apply the scale or dont
            #77371
              Can you post a link to your .blend file? Or are you satisfied with your workaround?
              #77372
              Norb Fry
                it does affect the final result, however your trick worked when i separated the hands from the body! thanks
              • The topic ‘emission map showing weird white spots please help’ is closed to new replies.
