E hotkey is doing extrusion instead of even
Forum Archive E hotkey is doing extrusion instead of even
  • #20123
    krishna chunduri
      Not sure why but at 20:00 when I try to do e it just does extrusion and not even. I ended up just doing the snap to vertices to make it even but I just wanted to know for the future if there’s something else you need to do to make Blender do even instead of extrude.
      #94789
        Hi @LoveBlendingSpinach ,
        CTRL+R gives a double Operation, first you place the Loop Cut (and scroll up or down to change the number of Cuts) and then confirm that with a Left Click, and then you can  Slide the Cut(s), until you Left Click again, to confirm. It is during this Slide Operation (between the first and second confirm) that you can use E for Even. When you have Left Clicked twice, the Cut(s) is (are) fixed and E will do an Extrude.
        #94790
        krishna chunduri
          Thanks I see it now. I noticed it was on the bottom too, 03 at 2.31.59 AM.png
        • The topic ‘E hotkey is doing extrusion instead of even’ is closed to new replies.
