DVC showing flat color to treasure chest
Forum Archive DVC showing flat color to treasure chest
  • #11105
    ishegeek
      For some reason, when I apply the dirty vertex colors to the curved bars on the treasure chest lid, it shows as a flat color instead of how it should look from the tutorial. This is at step 8:33 in this tutorial:
      https://cgcookie.com/lesson/edge-cavity-detection
      I have tried this two times (using a previously saved file) and re-listened to it about a thousand times to make sure I’m not missing a step or in the wrong view.
      This is what it looks like after I apply the Dirty Virtex Colors:
      Any ideas what I’m doing wrong?
      #52322
      Cookie Dough
        I would try doing it on one of the wood pieces first then change the highlight and dirt angles and play around with it, until you get a result you want.
        Also make sure you subdivided it.
        #52323
        ishegeek
          Thanks. I tried fiddling with all the settings that I could see and ended up just not using it. I did do the subdivision with the 3x setting that was used in the tutorial. Almost done, now I have camera issues. lol
        • The topic ‘DVC showing flat color to treasure chest’ is closed to new replies.
