Driver did not work.
Forum Archive Driver did not work.
  • #15852
    Craig Wieland
      Copied as new driver from the Text properties/ Geometry / Extrude. Then  Pasted the driver in 3D viewer/ N panel/ location Y.
      front Text object still moves back?
      #77175
        Hi Craig, if done right, it should look something like this:
        What does yours look like?
        #77176
        Craig Wieland
          sorry, I do not get Notifications, even when I click on the bell.
          #77177
          Wayne Dixon
            Did you get this one solved Craig?
            #77178
            Rob Koehler
              Mine looks exactly likes this yet when I move the driver from the N panel its snaps the numbers back to the original numbers. I believe I followed instructions exactly. At first I was working from the x axis. Then I tried it from the y. Same problem. Will try a new file and start from scratch.
              #77179
              Rob Koehler
                Ok what did work for me ( in 4.2) Not sure if this is a case of multiple ways of doing the same thing or its just wrong, but I did it completely backwards from the tutorial and it worked. Copy as a Driver from the N panel on whichever axis you are working, from then paste it on the Extrude value.
              • The topic ‘Driver did not work.’ is closed to new replies.
