Draw sharp problem
Forum Archive Draw sharp problem
  • #11421
    alinblender
      hey what were you using when you drew sharp between the teeth? Because my geometry looks so stretched when i do that
      #53355
        If you find your geometry is stretching that’s a clear indicator that you’re using the Crease brush. The only difference between crease and draw sharp is the pinch behavior.
        Switch to the Draw Sharp brush to avoid the pinching.
      • The topic ‘Draw sharp problem’ is closed to new replies.
