DRAW: Best Blender version / file format to submit “Brush Asset Library”?
Forum Archive DRAW: Best Blender version / file format to submit “Brush Asset Library”?
  • #21560
    Kevin Mather
      I have read through the previous questions and answers, and it still isn’t clear to me what/how to submit to pass this exercise. Asset handling works nicely in 5.0 which I had been using – is that acceptable? (I tried various things using 4.0 and 4.2, but didn’t manage to get any “Saved/Brushes”. I did with 5.0.)
      #100240
        Hello. Yeah I’d say asset handling is acceptable. And it seems like the exercise says you need to upload a blend file with the brushes you have created so they can be used. And there is a base file you can use as template which you can download.
        #100241
        Grady Pruitt
          I would agree with Omar… When Draw was originally recorded, I believe it was before the current Asset Tool Shelf, so doing the brushes the way Paul did was how it was done then, but now I believe you can use the same asset management you’d use in other parts of Blender and mark it as an asset.
        • The topic ‘DRAW: Best Blender version / file format to submit “Brush Asset Library”?’ is closed to new replies.
