Dragging reference images into Blender 2.8 viewport
Forum Archive Dragging reference images into Blender 2.8 viewport
  • #11710
    Ingmar Franz
      Just a quick update:  Dragging reference images into the Blender viewport also works with Blender 2.8 where the images are loaded as attachment to an empty so that image properties like size, position and opacity are set in the empty’s “Object Data” tab in the “Properties Editor”. Nevertheless, for this course I will use Blender 2.67 in order to focus on the creative part without need to search for equivalent settings in Blender 2.8.
      #55857
      Chris Vkr
        I don’t understand why you insist on using an old version
        #55858
        Ingmar Franz
          Quoting myself (April 14th  2020):
          After some months of gaining sufficient experience with Blender 2.8 and 2.9 I’m confident to quickly find the appropriate settings in the Blender 2.9x  GUI. It can only happen that some things don’t work in Blender 2.91 as in Blender 2.67. An example is the “Layer Brush” which has a “Known Issue” (according to the Blender developers here) concerning the “Set Persistant Base” functionality as I’ve described it here. See also here Kent Trammell’s article “Learning 3D through various Blender versions” with the recommendation
          Always use the same version of Blender that you see in the video.
          if you want to be sure that everything works as demonstrateted in the tutorials and courses.
        • The topic ‘Dragging reference images into Blender 2.8 viewport’ is closed to new replies.
