Do we have to learn the both engines' texture options or is it possible to stick with cycles render? From what I have seen…
Forum Archive Do we have to learn the both engines' texture options or is it possible to stick with cycles render? From what I have seen…
  • #4521
    kotoban
      Do we have to learn the both engines’ texture options or is it possible to stick with cycles render? From what I have seen, node editor is easier to use, can I just use it instead?
      #22701
      kotoban
        I found the answer in the upcoming lessons. The short answer is yes.
      • The topic ‘Do we have to learn the both engines' texture options or is it possible to stick with cycles render? From what I have seen…’ is closed to new replies.
