Do I need to apply the “Subsurf Modifier” when using the baken “Normal Map” in a game engine?
Forum Archive Do I need to apply the “Subsurf Modifier” when using the baken “Normal Map” in a game engine?
  • #12682
    Ingmar Franz
      Is it necessary to apply the “Subsurf Modifier” when using the baken “Normal Map” in a game engine or can I keep my original low poly mesh and use the “Subsurf Modifier” creatend “Normal Map” since it’s an image texture existing independently from any UV map grid?
      #60178
      Jonathan Lampel
        You do not need to apply the subdiv, which is good because that would slow things down quite a bit!
      • The topic ‘Do I need to apply the “Subsurf Modifier” when using the baken “Normal Map” in a game engine?’ is closed to new replies.
