Derek’s Polybook | CORE | Fundamentals of 3D Mesh Modeling in Blender
Forum Archive Derek’s Polybook | CORE | Fundamentals of 3D Mesh Modeling in Blender
Viewing 15 posts - 1 through 15 (of 30 total)
  • #18934
    Derek Chestnut
      I’ll be using this thread to share the content I produce while attending CORE | Fundamentals of 3D Mesh Modeling in Blender.
      The project is here; use that link to visit the project’s web page here at CG Cookie to see the content rendered in Full HD and to inspect the models for critique. I’d appreciate help identifying any weakness(es) in my skill set, if you find them.
      Following along with the course as instructed, here is the content produced during the first lesson:
      03 | Modeling a Snowman with Primitives
      #90213
        Wow great render. Not only a cute snowman but the presentation is very artistic. Nice job Derek 🤘🏻
        #90214
        Derek Chestnut
          I had the benefit of attending PRESS START | Your Simple First Blender Project before beginning this course; it’s recommended as a direct follow up to Blender Basics.
          I was introduced to rendering in that course, so I did have a basic idea of how to arrange this scene for rendering.
          #90215
          Derek Chestnut
            Wrapping up the next lesson, here are the results for:
            04 | Modeling a Sci-fi Crate
            ** Once again, use the link provided in the opening thread if you’d like to inspect the model.
            #90216
            Derek Chestnut
              Burning the midnight oil…
              08 | Modeling a Soccer Ball
              #90217
                Excellent Crate Derek! And a great presentation as well👍🏼
                The only thing I noticed, and this is really nitpicking and absolutely nothing that would need to be changed, is that this seems to be unintentional (I’d expect parallel Edges there, not converging):
                The Ball is perfect and again, a great presentation!
                #90218
                Derek Chestnut
                  So that must have happened then during the bumper extrusion, maybe? what type of action(s) result in this type of error?
                  edit:
                  So I just inspected the wireframe to get a better look at what is going on, and I don’t think it’s an actual topology error, because all of the bevels have the same number of edges; I think the operation just smushed the edges close enough together that it looks a little off to the human eye; a little bit of manual cleanup via edge spacing and I think this problem can be resolved?
                  #90219
                    It could be cleaned up manually, but I wouldn’t be bothered if I were you; it’s not really an error or a problem, just something to keep an eye out for in the future (doesn’t mean, that this will happen again, of course, I don’t remember having seen it before…)
                    For a ‘fix’:
                    If you enable (install?) the Edit Mesh Tools Addon, you can set the Edge Length of the smaller Edges to be the same as (one of) those longer ones, for instance…something like this, maybe:
                    #90220
                    Derek Chestnut
                      I haven’t gotten into using add-ons quite yet, but I’ll jot the name of that one down in my notes as one to experiment with when I do.
                      I appreciate your taking the time to provide input!
                      #90221
                      Derek Chestnut
                        This one here had a few ups and downs…
                        18 | Modeling a Hard Drive
                        #90222
                          Daaaangs, great presentation. Love the white balanced lighting here. Super good job Derek 🤘
                          #90223
                          Derek Chestnut
                            Wrapping the logo was a nightmare…
                            20 | Modeling a Coffee Cup
                            #90224
                              Love the pedestal!
                              But wait…the logo is geometry??? That would explain why you had so much trouble to get it wrapped correctly; super impressive!
                              #90225
                              Derek Chestnut
                                Yeah, the logo is geometry; it is made of a text object converted into a mesh and joined with the frame.
                                I kept running into problems though when it was time to wrap it around the coffee cup, and I wasted so much time making tiny mistakes on things that I either have a knowledge gap on, or operations I haven’t cemented in my skill set yet; I began to get very frustrated, because I had the right idea from the start, but I was missing something each time I tried the operation, until finally, I learned all of the little tricks.
                                It took hours and I started to get disgusted with how much time I was wasting just failing and failing and failing…
                                In the end, I succeeded by:
                                • converting the text into a mesh object.
                                • converting the surface of each letter into an n-gon (this was necessary to prevent lighting concerns)
                                • model the frame from a plane (paying careful attention to ensure it had enough geometry to distort)
                                • joined the two meshes into a single object
                                • creating a lattice object (taking care to ensure it had the proper resolution for distorting)
                                • parenting the logo to the lattice (the logo was a child of the lattice, not the other way around)
                                • adding the lattice modifier to the logo object and assigning the parent lattice object as the deformer
                                • utilizing a shrink-wrap modifier on the lattice object (shrink-wrapped the lattice, not the logo)
                                • set the logo’s shading to smooth
                                The whole thing was a big heaping pile of frustrating, but I’m glad to have stuck with it and learned how to utilize the lattice modifier in tandem with the shrink-wrap modifier, because this combination allows you to wrap any object around any surface, granted you’ve modeled them with enough supporting geometry.
                                #90226
                                  Yeah, you can learn sooo much from sticking with it this way!
                                  But for the future, in situations like this, people usually just use a Texture, either in the Cup Material itself (needs an Unwrap of the cup), or just on a Plane (with transparency), that can be Subdivided and ‘Shrinkwrapped’ (Shrunkwrapped?) on the cup.
                                • The topic ‘Derek’s Polybook | CORE | Fundamentals of 3D Mesh Modeling in Blender’ is closed to new replies.
