Cycles Render settings in Blender 2.93
Forum Archive Cycles Render settings in Blender 2.93
  • #14353
    Dhamesvara
      Blender 2.93 doesn’t seem to have Cycles render settings in the particles tab (discussed from 3 min 40 s onwards ). Do you have it covered in some other tutorial on CG cookie? Thanks!
      This is a great course, and so far I have been able to find everything else mentioned here in Blender 2.93.
      #70487
        Indeed the rendering settings have been completely changed; for Cycles you now have only two options: faster or more accurate and you can find them in the Cycles Render Properties:
        And for the shading of the hair, we now have a Principled Hair Shader, which @jlampel  explains here:
        https://cgcookie.com/tutorial/using-the-principled-hair-bsdf-in-blender-2-8
        #70488
        Dhamesvara
          @spikeyxxx Thank you very much for the prompt and detailed answer!
        • The topic ‘Cycles Render settings in Blender 2.93’ is closed to new replies.
