Cube are changing from smaller to larger cubes (blender 4.2)
Forum Archive Cube are changing from smaller to larger cubes (blender 4.2)
  • #18982
    Michael Joseph
      Hi there, for some reason when I use “separate geometry,” it all looks good until I try to change the “W” slider on the noise texture to animate it. While doing the wavy pattern, the cubes will randomly switch between the larger ones to the smaller ones, and vice versa.
      I would love to share if a screenshot if I could remember how to upload it on here haha. Thanks in advance!
      #90454
      Michael Joseph
        Figured out how to share the screenshot. Here’s my setup that is somehow causing the cubes to change from the smaller to the bigger ones:
        #90455
          Hi Michael,
          That is because your Voronoi Texture is 3 dimensional, so, if a Cube Instance changes its Z Position, it also changes where it is in the ‘cloud’ of Voronoi Values (or Color). Change the Voronoi to 2D and all should be fine.
        • The topic ‘Cube are changing from smaller to larger cubes (blender 4.2)’ is closed to new replies.
