Creating an all quad soccer ball
Forum Archive Creating an all quad soccer ball
  • #14454
    3D_DC
      I wanted to see if I could make an all quad soccer ball and this is what I came up with.
      1. Start with an ico sphere with 1 subdivision.
      2. Bevel all vertices (not edges) to create the base tiles.
      3. Add a subdivision surface modifier, switch it to simple, set it to 2, and apply it.
      4. Add a separate UV sphere object and scale it to match the ico sphere.
      5. Add a Shrinkwrap modifier to the ico sphere, select the UV sphere as the target, and apply it.
      6. Select the faces that make up a tile of the soccer ball and extrude them a bit along the normal. Repeat this step and make sure to extrude the exact same amount until all tiles are extruded.
      Soccer ball mesh:
      Soccer ball with bevel and subdivision surface modifiers:
      #71107
      Jonathan Lampel
        Nice one, I like how you took this exercise one step further and this looks like a great result!
      • The topic ‘Creating an all quad soccer ball’ is closed to new replies.
