Could you use the subdiv “use custom normals” feature instead of subdiving the nromals fix object?
Forum Archive Could you use the subdiv “use custom normals” feature instead of subdiving the nromals fix object?
  • #14407
    brandon schaffer
      If you have zero subdivisions on your normal fix, and put the data modifier first using the use custom normals option will, you get the same result or will that create different shading issues?
      #70952
      Jonathan Lampel
        That kinda works if you’re viewing it from farther away, but unfortunately it gets rid of the crisp shading from the subdiv modifier:
        #70953
        brandon schaffer
          Drat that would have been a lot more convenient if it worked.
          Thanks for testing.
        • The topic ‘Could you use the subdiv “use custom normals” feature instead of subdiving the nromals fix object?’ is closed to new replies.
