Copying physics settings from one object to another.
Forum Archive Copying physics settings from one object to another.
  • #19064
    Nathi Tappan
      In the Rigid Bodies chapter Kenny showed us how to copy the physics settings from one object to another: Object / Rigid Body > Copy from active.
      Do we really just have that option for Rigid bodies and none of the other physics settings? Or is it hidden somewhere else?
      #90766
      Nathi Tappan
        I ended up testing just the good ol’ “Copy modifiers” and that did it 🤷🏻‍♀️
        But it did not copy the “Collision”. Just the soft body 🤔
        #90767
          Hi Nathalia,
          Yes, CTRL+L > Copy Modifiers only seems to Copy the last Modifier in the stack.
          If, however, you install the Addon Copy Attributes Menu, the CTRL+C > Copy Modifiers, copies all Modifiers. There is also an option to Copy Selected Modifiers.
          #90768
          Nathi Tappan
            Nice! I’ll definitely enable that one. Thanks Martin.
            #90769
            Alex Page
              Another option, when you have a bunch of objects selected, you can hold Alt while changing a setting, and it will be applied to all of them.
            • The topic ‘Copying physics settings from one object to another.’ is closed to new replies.
