Copy topology
Forum Archive Copy topology
Viewing 10 posts - 1 through 10 (of 10 total)
  • #15599
    maxcady
      Is thee a way to copy a topology without a mirror modifier?
      #76153
        You can do normal copy paste in Blender. There’s also the Copy Attributes Menu that you can enable as an addon which is really handy. It replaces the Control + C with lots of helpful options.
        #76154
          If you don’t have a relevant Local Orientation for the part, make a Loopcut through the middle:
          And use that as a Custom Orientation. Then you can SHIFT+D (copy) and S, X or Z, -1 (paste) remove original if needed and M > Merge > by Distance.(Watch out: creates inconsistent Normals! Run SHIFT+N!). Doesn’t work in all cases, but in most.
          Special Case:
          SHIFT+D, Y:
          gives:
          Now that’s what I call Blender magic….
          #76155
          maxcady
            What is the addon for copy attribute?
            Magnet problem again. I don’t fully understand yet.
            #76156
              maxcady
                How do you activate it?
                #76158
                  You go to Edit -> Preferences and in the addon tab you look for Copy Attributes, and you enable it with the tick. Then in the viewport with control + C you call that menu with the handy features.
                  #76159
                  maxcady
                    that was CTRL + C I wanted to know. thx
                    #76160
                      @maxcady
                      A little tip, if you use the dropdown arrow of an Addon, you get some extra information, like where to find/’activate’ it:
                      #76161
                      maxcady
                        Ho yeah, I learned that trick accidentally in a Youtube video.
                      • The topic ‘Copy topology’ is closed to new replies.
