(Comment+props) Really learned a lot from this. Especially "glossy over bump" to produce internal refraction – works like …
Forum Archive (Comment+props) Really learned a lot from this. Especially "glossy over bump" to produce internal refraction – works like …
  • #5987
    Kevin Mather
      (Comment+props) Really learned a lot from this. Especially “glossy over bump” to produce internal refraction – works like a charm but is certainly non-intuitive.
      #24725
      Kevin Mather
        One note: I started with an empty .blend file, added a mesh, and tried the dispersion technique; wasn’t getting anything to happen. Then I noticed the mesh dimensions (quite small) in the example file. Scaled down my mesh greatly to 0.1-0.2 BU range, and voila. Apparently [node scale] x [mesh max dimension] must be around 2.0.
        #24726
        Kevin Mather
          Absorption, not dispersion (arrgh)
          #24727
            Good point – The absorption isn’t synced with the scale of an object. Thanks for offering advice about node scale x mesh dimension!
            And thanks for watching the course offering positive feedback 🙂
          • The topic ‘(Comment+props) Really learned a lot from this. Especially "glossy over bump" to produce internal refraction – works like …’ is closed to new replies.
