Color from plane reflects on object
Forum Archive Color from plane reflects on object
  • #19684
    Bart Kestemont
      Hi, I’m new with Blender and I have a problem. The color of the plane reflects on my 3D object. How can I fix this?
      Thank you!
      #93130
        Hi Bart,
        That is normal. To break the realism, you could, for instance, use a Light Path Node:
        #93131
          Yes that’s called bounce lighting, from the fact that Cycles works with global illumination and so color spilling over to your model is how it actually works in the real world. Apart from what Martin is suggesting, you can also render both the object and the background separately and putting them together again in post.
          #93132
          Bart Kestemont
            Thank you Martin, it worked! 😀
          • The topic ‘Color from plane reflects on object’ is closed to new replies.
