COLLAB2021 – WIP – hunter-x
Forum Archive COLLAB2021 – WIP – hunter-x
Viewing 2 posts - 31 through 32 (of 32 total)
  • #66253
      Great work @hunter-x! You finished strong with your vase. Looks good in the assembly:
      I tweaked the reflections a bit and also added a subtle gradient + sheen to the spice pile:
      Thanks for joining Collab2021! It’s been a pleasure working together 🤝
      #66254
      Matthew Halls
        @theluthier Thanks for having me!
        I had a look through your tweaks to the model; I’d experimented with using Roughness for the glaze after seeing a couple of the other vases use it but decided I preferred the way Clearcoat produced a smooth layer on top of the rough surface of the clay (with Roughness it clings a bit too tightly to the surface of the vase for my taste if that makes sense). That said, as project lead you of course have final say on the way the models are presented in the scene itself 🙂 Out of curiosity, was the change more of a stylistic thing or are there performance considerations when using Clearcoat? The changes to the spice look good though and help make the edges stand out a bit more.
        I’ll probably combine elements of your version and mine for my personal renders (and stick them in a third WIP file on the Drive for anyone who wants them). Would it be better for me to start from WIP_acc_vase-B_hunter-x_01.blend or MASTER_acc_vase-B_hunter-x.blend in the event that you want to bring anything from that version into the scene model?
      • The topic ‘COLLAB2021 – WIP – hunter-x’ is closed to new replies.
