Collab 2020: Modeling Heavy Equipment (Backhoe)
Forum Archive Collab 2020: Modeling Heavy Equipment (Backhoe)
Viewing 15 posts - 1,036 through 1,050 (of 1,440 total)
  • #54812
    artifact
      @theluthier  Thanks, Kent. Hoping @adrian2301 is amenable to a change…
      #54813
        I’m glad Kent made the Google Drive folder for the files, if it had been up to me I’d probably make 4 different folders for the files to live in and name them after the Hogwarts houses. And then Kent in the livestream would be like, Adrian Engine will be in…… Griffindoroooorf!
        #54814
          To be clear: you normally would never try to visualize a number (if you feel the urge to do that, then that is probably a left-over urge from when you first learned about numbers by counting buttons or apples or cakes or sheep…which results in  a really clumsy way of adding two integers (counting five apples, counting three apples, putting them together on one heap and counting them again) and getting ridiculous as soon as you get negative numbers…or fractions: divide one cake by four people, WTF! Then how do I divide two bananas by three carrots or one apple by seven sins? No wonder children have problems with learning to calculate…), say you have to calculate 5 * 3, you don’t imagine two points on a line, representing 3 and 5 respectively, now do you? And how would you visualize the multiplication?
          The only reason we do that (visualizing numbers) with the complex numbers is to show that a multiplication in C describes a rotation and therefore a 2D rotation can be described as a multiplication of complex numbers. Once you understand that, it is a ‘small’ step to understand that a 3D rotation can be described by the multiplication of quaternions (again: quaternions are numbers!).
          #54815
            Your approach is way cooler though. Mine is life less and…
            #54816
            Adrian Bellworthy
              I will have a look and see what can be done. Won’t be today but consider it taken care off.
              #54817
              Adrian Bellworthy
                I have made some progress with the hydraulics around the swing frame today, @jakeblended achieved a good stage, only maybe some tweaks here and there, and finish the hydraulics.
                #54818
                  We are all Gryffindorf material anyways. Expect Adrian, that boy accomplishes too much.
                  #54819
                  Karen Trevino
                    This would be my approach…. 😂
                    #54820
                    Adrian Bellworthy
                      Karen Trevino
                        WOW!
                        #54822
                          Uhh….ditto Karen’s reaction
                          #54823
                          artifact
                            @adrian2301 Thanks Adrian
                            #54824
                            Adrian Bellworthy
                              Job Done!!!!
                              Swing Frame Hydraulics.
                              #54825
                              Karen Trevino
                                Someone pick my jaw up off the floor! wow
                                #54826
                                Adrian Bellworthy
                                  @theluthier , do you want me to attach your hoses from the digger arm to the swing frame hoses??
                                • The topic ‘Collab 2020: Modeling Heavy Equipment (Backhoe)’ is closed to new replies.
