cockpit is out of shape
Forum Archive cockpit is out of shape
  • #16622
    Martin Starchel
      Hallo
      When I try to extrude the wings also my cockpit goes off. It happens with the shrinkwrap. I made a video.
      Every time when I add the Vertex Group it bends… can’t figure out why…
      Thank you for helping me
      #80227
        Hi Martin,
        I’m intrigued:
        It looks as if the ‘Body’ of the Plane stops being Shrinkwrapped when you enable the Vertex Group influence (it ‘grows bigger’).
        Double-check your Vertex Group and maybe post a link to your .blend…
        #80228
        Martin Starchel
          Hallo Martin
          thank you and sorry for my late response. Vertex Group is correct.
          I have my Blend File in Protonmail-Drive https://drive.proton.me/urls/DXXJZEZD88#9EdoCn6WTAQF
          Thank you for your help. I started over again btw with a new file and it happened again…. very strange, couldn’t figure out what the cause for this is.
          #80229
            I added the whole body except the wings to the vertex group and it’s working correctly. Also applied the mirror modifier but I think that didn’t make any difference.
            #80230
              Hey Martin,
              I haven’t rewatched the tutoorial, so I don’t know how Jonathan did this part, but I think you don’t want the wings to Shrinkwrap to the Body, so that Vertex Group should be excluded from the Modifier:
              The way you had it set up, only the Wings were Shrinkwrapped to the Body.
              #80231
              Martin Starchel
                Martin, Oar, Thank you… I understood Jonathans process not correctly…. again become aware that I should look at lessons beforehand and than start modeling. 😉
              • The topic ‘cockpit is out of shape’ is closed to new replies.
