Character rigging: Use Displacement map, Normal map, shrink wrap?
Forum Archive Character rigging: Use Displacement map, Normal map, shrink wrap?
  • #13146
    klonkster
      Hi there, I am taking the Introduction to Character modeling course. I’m currently retoplogizing the character’s head and am curious how does one rig and animate a character’s high-poly detail? I know you rig the low-poly retop mesh, but how do you retain the high details and have them deform properly? Is it through applying a displacement map or normal map, or do you add/apply a shrinkwrap modifier and will that do the trick? Any tutorials or details on this process would be super helpful, thanks!
      #61787
      coyo
        Hello!
        The typical solution to this is to bake and apply a normal map to your retopologized object. I’m not sure if there is a character-specific tutorial on how to do so here on CGC but this course covers the basics:
        https://cgcookie.com/course/intro-to-normal-map-modeling-for-games
        The course uses 2.78 but the theories and workflow are the same.
        #61788
        klonkster
          Thanks so much!
        • The topic ‘Character rigging: Use Displacement map, Normal map, shrink wrap?’ is closed to new replies.
