Changes to weight painting in Blender 4.5
Forum Archive Changes to weight painting in Blender 4.5
  • #20269
    Kaya Jordan
      Unless I am missing something, It appears as if some of the weight painting options have been re-organized as a part of the 4.5 update. Most noticeably while viewing this tutorial compared to my version of Blender, my brushes are different. The whole menu is different to the version in this tutorial, but I assume that the same options are available elsewhere in the new layout. Is anybody able to give a quick debrief on where the important tools have been moved to so that I may more easily follow these tutorials?
      #95295
      Dwayne Savage
        You may want to check out the 4.3 brush asset workflow
        https://developer.blender.org/docs/release_notes/4.3/sculpt/
        #95296
        Wayne Dixon
          Seeing your submissions earlier today, it looks like you haven’t had much trouble with the changes.
          Have you managed to figure out the differences from 4.2?
          #95297
          Shannon Lenz
            Hi, I too am having trouble with the brushes in weight paint mode. Choices are Average, Blur, Paint and Smear. Add is not an option. I am also not able to select the individual bones with my cursor even though the bone icon is active. When trying to select a bone it starts painting instead. Again when I don’t have a bone listed and start to paint, it does not turn magenta but starts painting.
            #95298
            Dwayne Savage
              Paint brush set to draw brush type(Under advanced when you click on brush in the header) is the same as draw.  Change the blend mode(at the top of the brush settings) from Mix to Add. That will be the same as the add brush in older versions. If you change it to Subtract it is the same as the subtract brush. As for selecting the bones are you using shift+ctrl+left click? or Alt+left click. Older versions used ctrl+left click.
              #95299
              Wayne Dixon
                Hi @hawkline13 – I can see you have submitted your weight painting exercise and figured out the differences.
                Well done.
                #95300
                Shannon Lenz
                  Hi Wayne, Thank you for personally reviewing my posts and guiding me through this dense and confusing subject. I very much appreciate it, as I’m sure everyone else taking this course does. Now on to the next challenging lessons.
                  #95301
                  Shannon Lenz
                    BT, I was able to fix that errant vertex connected to the ear on the back of the monkey head. Yipee!
                  • The topic ‘Changes to weight painting in Blender 4.5’ is closed to new replies.
