Was curious, does this present a problem not having the (body) and (body_block) centered on the (y) axis? Should be able to see this from the side view next to the cone area. I’ll add a pic to show. Pretty sure I screwed that up when I started moving those two around in object mode. Also, I currently working on the cone/nose area, that’s when it caught my attention. One more thing, how do I get my objects to load in the center again. For the cone by adding the new mesh(cylinder), it loaded in the top right corner of my 3D view. I’m guessing that has something to do with the cursor? Thanks for any feed back!
